F
fantom
Guest
Hi, Was having issues with IPSec VPN client not working (I do not know if it worked before, because I used different VPN client until recently) and tracked it down to the QoS feature. If QoS is disabled, I have no issues with the IPSec VPN client and if QoS is enabled, then the VPN client cannot establish a connection.
Anyone has any insight into this? Thanks in advance.
Update: I have noticed that QoS is only an issue when establishing an IPSec connection. Once it is up, I can enable QoS back and everything works until the connection drops.
