sfx2000
Part of the Furniture
QTS4.2
QTS4.2.0 Build 1118
[Change]
[Bug Fixes]
QTS4.2.0 Build 1118
[Change]
- Due to the lack of compatibility with DVB-T TV dongles, the Digital TV Station app will be removed from the QTS 4.2 App Center in certain regions. If compatibility improves, then the app will be reinstated.
[Bug Fixes]
- Fixed an issue where the NAS could not enter hibernation mode if a network cable is unplugged.
- Fixed an issue where the NAS would display "The File system is not clean." in the system logs after setting up a scheduled shut down. - Fixed an issue where the NAS could not enter standby mode is a network cable is unplugged.
- Fixed an issue where NAS drives could not enter standby mode if you change the time setting from "Synchronize with ...." to "Manual setting" in the Control Panel.
- Fixed an issue where the NAS would fail to create scheduled snapshots when using Snapshot Agent Manager.
- Fixed an issue where if the NAS reboots while a RAID is resyncing (RAID6), the RAID will be inactive after the reboot.
- Fixed an issue where File Station fails to copy files larger than 30MB from a local device to OneDrive.
- Fixed an issue where Download Station can still download files with an incorrect proxy setting.
- Fixed an issue where RAID groups would become "inactive" after rebooting the NAS when the QNAP signature on the disks is missing.
- Fixed an issue where the TVS-871T would keep trying to recover from an error if it is connected to 2 Thunderbolt devices at the same time.
- Fixed an issue where the TVS-871T could not establish a Thunderbolt link with a Mac via Thunderbolt cable.
- Fixed an issue where the TVS-871T may not produce a Thunderbolt IP after updating to a new firmware.
- Fixed an issue where a TS-871T will fail to reconnect over Thunderbolt after the NAS wakes up from hibernation mode. - Fixed an issue where a 10GbE NIC will be disconnected after the NAS goes into hibernation mode.
- Fixed an issue where it will fail to open the Credential Manager on Windows 8.1 when the Domain Controller is enabled on the NAS.
- Fixed an issue where the Next button of "iSCSI Target Only" is disabled while a thin volume is created and its status is "Ready".
- Fixed an issue where the NAS is unable to backup files with the one-touch button when a Sony SBAC-UT100 card reader is in EXT4 or EXT3.
