Question about sys log msg
d_v_us
Hey guys, getting this msg in my sys log of:
kernel: protocol 0800 is buggy, dev eth6
not sure if I should be investigating further but it keep scrolling with that so I’m thinking it’s serious?
Model: ASUS RT-AX86U
Firmware: 386.2_2
Aimesh enabled:
Node is: RT-AC86U
Firmware: 386.2_4
be gentle…as you can see…I only know enuff to be dangerous:)
Often related to Guest Network #1. Usual suggestion is to move to Guest Network #2 or #3.
Ah ok…I’ll check that out…
I’ve heard of havin problems on a eth01 or 02…but never eth6…thanks:)
Do you have IPv6? If not then disable it in the WebUI, if you do have IPv6, try to change to Native and see if the message disappears.
https://<your router IP>:<your portnumber (optional)>/Advanced_IPv6_Content.asp
Firmware: 386.2_2
Aimesh enabled:
Node is: RT-AC86U
Firmware: 386.2_4
This may stop the error log, but If he switches to GN 2/3 what happens to the node GN? He runs AiMesh.
Looks like this might have got rid of it?
But your guest network will no longer be available on the AiMesh Node, as Tech9 alluded to. Can you confirm that?
Yep guest network still available via aimesh
Are you sure? If you are, connect to the node GN and try to access devices on the main network. What's the result?
"Note: Guest network is currently designed to allow the first set of each band (2.4G, 5G, 5G-1) available to the AiMesh node."
Source: https://www.asus.com/support/FAQ/1045327/
put myself on GN and accessed my main router and went and looked at system log and other settings.
Full disclosure: I cheated though....when I went and added myself...checked off that box "access intranet" Enable:)
