I have an HP Procurve switch and have a FreeNAS server attached with a 1Gbit motherboard NIC. I am trying to crank up speed on the server. The switch has an option for flow control which can be set for each switch port. Switch default was to have flow control option turned off. I am not running Jumbo frames. Is it better to go with the flow control or leave it off with this setup?
