Rackmount UPS - suppestions
The_Tango
Looking to buy a rackmount UPS for 2 file servers. Anyone have any experience with different brand of UPS. (Each server has 12 hard drives)
You need to know what the real power usage from each server is. Some newer server can tell you that from IPMI interface. For something older you might have to use a WattsUp or equivalent. Once you know the real usage, then you can start sizing a UPS. The APC website has good tools. I like the SmartUPS line of dual conversion UPSs.
I was more interested in peoples experience with brand - longevity, included software, battery replacement cost, overall which brand is best bang 4 buck.
APC has the biggest market share. They are pricey.
Battery replacement is absurdly expensive. Cheaper to buy a Costco car battery and wire it up!
My home stuff uses a CyberPower 1500VA. Battery is still good after 2-3 years.
You can replace the batteries (only) in an APC UPS, rather than buying their overpriced RBC packs. I cover this in detail in 2 of my blog posts:
New Year, new UPS batteries…
[Another] New Year, new UPS batteries…
APC units have a disturbing tendancy to drift out of calibration over time. This causes the float voltage to rise above the limit the batteries can take. Some newer units can calibrate this via the serial port. Of course, APC considers all information, even about long-discontinued product lines, as proprietary info and won't sell / give you any information.
Without calibrating the float, one battery pack replacement (normally when the first set fails, at 2-3 years) is all you'll get and that one won't last as long as the original ones. That is the reason APC no longer offers their "Charge-UPS" program, whih extended the warranty on the UPS when you bought replacement batteries and paid the Charge-UPS fee. That's because they know they've "price engineered" their products to last as long as the warranty, bot not much longer.
Also, APC required repeated clubbing with clue-by-fours by a large mob for over FOUR YEARS before they made changes to let free software like apcupsd and NUTS work with their [now not-so-recent] new models. If you required that support, you should check with APC to make sure it is available in whatever product you plan on purchasing.
If it were me, I'd buy a later-build "legacy" unit used and replace the batteries, and calibrate the float voltage. Just make sure you get the rackmount hardware for it - APC is also notoriously bad at selling replacement parts like that.
My cyberpower 1500VA has run fine for a long time - for home use. But, if you want rack mount, want ethernet signaling, etc., APC is probably the choice.
