asus-router
I own a RT-AC3200 which is stuck on 384_13.10.
However, there is a serious bug in router/rc/udhcpc.c:
int dhcp6c_wan(int argc, char **argv)
if (argv[2]) run_custom_script("dhcpc-event", 0, argv[2], NULL);
if (!argv[1] || !argv[2])
return EINVAL;
else if (strcmp(argv[2], "started") == 0 ||
strcmp(argv[2], "stopped") == 0 ||
strcmp(argv[2], "unbound") == 0)
return deconfig6(argv[1]);
else if (strcmp(argv[2], "bound") == 0)
return bound6(argv[1], 1);
else if (strcmp(argv[2], "updated") == 0 ||
strcmp(argv[2], "rebound") == 0)
return bound6(argv[1], 2);
else if (strcmp(argv[2], "informed") == 0)
return bound6(argv[1], 0);
else if (strcmp(argv[2], "ra-updated") == 0)
return ra_updated6(argv[2]);
return 0;
This must read ra_updated6(argv[1]) : see
static int
ra_updated6(char *wan_ifname)
Because of this bug, ipv6 dhcp does not get an updated prefix, when the DSL router reconnect. rc then tries to reconfigure an interface called "ra-updated" instead of eth0, what is arg[1].
Can somebody please direct me to how I can recompile the sources for AC-3200? So I get at the end a trx-file that can be flashed? Thanks.
return EINVAL;
return 0;
static int
