Hi All--
I'm looking for a new router/firewall/all in one that can address my needs. The most important of which is stability/performance for VPN connections. I am doing a lot more remote work which requires me to VPN back into my own network for access to my lab, infrastructure etc. Having to explain to my spouse to reboot a specific piece of equipment isn't something I want her to have to worry about.
I've debated going the AC87u route for simplicity but am starting to look at more robust SMB solutions including pfsense, Sophos, fortigate, watchguard, barracuda, cisco RV series, and sonicwall. And getting overwhelmed.
I have dual home connections (family on cable and fiber optic for my business) so managing them both under one device would be nice but definitely not a requirement. I have a separate WAP and will most likely be putting in some ubiquiti ap's in my house in the near future to upgrade.
I need a solid solution that can handle VPN traffic and the few internal VLANs that I run internally. Next big requirement--something that's user friendly and quick to setup and be up and running but that I won't find I'm limited by a few years down the road. That's one of my pet peeves and regardless if I ever do use it I hate trying to do something after a purchase then being limited by the solution that I've chosen. Networking is the biggest of the technology black holes for me and one that I'm not an expert in. I know a bit more than the average joe but by no means an expert.
Budget is open at this time but ideally in the sub 1k range.
What would you recommend if you were in my place? Thanks in advance for the advice--it's much appreciated!
