I have couple question for Repeater setup. I have R7000(stock fw) as primary router and trying to use RT-AC68R as repeater. I have a static IP assigned to 68R on the same subnet and the bridge is configured over 5Ghz band. I currently can connect to 68R over 2.4 Ghz wifi or cable fine.
Questions
1. Do I want/need to use the same SSIDs for both 2.4 and 5 Ghz bands
2. How do I change the channel on wifi if it's possible at all?
3. Can I connect to 68R on 5 Ghz band if it's being used for bridge?
Thanks in advance.
Questions
Thanks in advance.
