The firewall rules including those on the port forwarding and related filtering does not seem to work for a VPN connections. This is due to the traffic being routed to the tunxx interfaces rather than the eth0 default interface. At the moment the only solution is to add the custom iptables rules by ssh to the router and run the necessary iptables command for port forward. This method however will not a survive a reboot unless written to jffs.
Is it possible to add this feature, to add a custom rules page for iptables entry in the firewall settings that will save the settings OR add interface selection in the Virtual Server/Port Fowarding of the WAN settings?
Thank you
Thank you
