Reverse proxying router config
kayson
I'm trying to use apache2 to reverse proxy a connection to my router config from the outside world, but I'm having some trouble getting it to work.
If I access my reverse proxy url: https://router.domain.com, the login page comes up just fine. However, if I put in the correct user/pass, it just reloads the login page.
Interestingly, if I access the router config locally, via 192.168.1.1, and put in the wrong password, it gives me the following response:
HTML:
<HTML><HEAD>
<script>parent.location.href='/Main_Login.asp';</script>
</HEAD></HTML>
However, if I do the same thing via my reverse proxy, I get:
HTML:
<HTML><HEAD><script>top.location.href='/Main_Login.asp';</script>
</HEAD></HTML>
I have no idea why the response is different. The requests are being sent the same, though I can't say exactly how the reverse proxy modifies it. I see no errors in my apache2 logs, and nothing in the router logs to speak of.
Anyone have any ideas how to debug this?
What I did that worked was add this after the proxy_pass line on the proxy site config:
This is on nginx by the way. Will need "translation" if on apache.
proxy_set_header  Host $host;
proxy_set_header  X-Real-IP $remote_addr;
proxy_set_header  X-Forwarded-Proto https;
proxy_set_header  X-Forwarded-For $remote_addr;
proxy_set_header  X-Forwarded-Host $remote_addr;
Complete subdomain reverse proxy file for reference:
  • note that I use http auth as another layer on top of the login page when accessing from outside
  • also note that this is using one of linuxserver.io containers for letsencrypt/nginx reverse proxy
# make sure that your dns has a cname set for plex, if plex is running in bridge mode, the below config should work as is, for host mode,
# replace the line "proxy_pass https://$upstream_plex:32400;" with "proxy_pass https://HOSTIP:32400;" HOSTIP being the IP address of plex
# in plex server settings, under network, fill in "Custom server access URLs" with your domain (ie. "https://plex.yourdomain.url:443")
server {
    listen 443 ssl;
    server_name asus.*;
    include /config/nginx/ssl.conf;
    client_max_body_size 0;
    proxy_redirect off;
    proxy_buffering off;
    # enable for ldap auth, fill in ldap details in ldap.conf
    #include /config/nginx/ldap.conf;
    location / {
        # enable the next two lines for http auth
        auth_basic "Restricted";
        auth_basic_user_file /config/nginx/.htpasswd;
        # enable the next two lines for ldap auth
        #auth_request /auth;
        #error_page 401 =200 /login;
        include /config/nginx/proxy.conf;
        resolver 192.168.1.1 valid=30s;
        set $upstream_asus asus;
        proxy_pass https://192.168.1.1:8443;
server {
    listen 443 ssl;
    server_name asus.*;
    proxy_redirect off;
    location / {
Would you be willing to share the rest of your config? I've been struggling a little with mine but it appears you have the same setup as I do.
Thanks I appreciate your help too!
Right now it is:
server {
    listen 443 ssl;
    server_name asus.*;
    proxy_redirect off;
    location / {
        #proxy_pass http://$upstream_plex:32400;
        #proxy_set_header Upgrade $http_upgrade;
        #proxy_set_header Connection "upgrade";
        #proxy_set_header X-Plex-Client-Identifier $http_x_plex_client_identifier;
        #proxy_set_header X-Plex-Device $http_x_plex_device;
        #proxy_set_header X-Plex-Device-Name $http_x_plex_device_name;
        #proxy_set_header X-Plex-Platform $http_x_plex_platform;
        #proxy_set_header X-Plex-Platform-Version $http_x_plex_platform_version;
        #proxy_set_header X-Plex-Product $http_x_plex_product;
        #proxy_set_header X-Plex-Token $http_x_plex_token;
        #proxy_set_header X-Plex-Version $http_x_plex_version;
        #proxy_set_header X-Plex-Nocache $http_x_plex_nocache;
        #proxy_set_header X-Plex-Provides $http_x_plex_provides;
        #proxy_set_header X-Plex-Device-Vendor $http_x_plex_device_vendor;
        #proxy_set_header X-Plex-Model $http_x_plex_model;
server {
    listen 443 ssl;
    server_name asus.*;
    proxy_redirect off;
    location / {
Thank you! This worked for me. Apache automatically sets those headers (except X-Forwarded-Proto, which I manually added). I think my issue was needing to set ProxyPreserveHost. New config below:
<IfModule mod_ssl.c>
        <VirtualHost *:443>
                ServerName router.domain.com
                Include /etc/apache2/ssl.conf
                <IfModule mod_proxy_http.c>
                        RequestHeader set X-Forwarded-Proto "https"
                        ProxyPreserveHost On
                        SSLProxyEngine On
                        SSLProxyCheckPeerName off
                        ProxyPass "/" "https://192.168.1.1/"
                        ProxyPassReverse "/" "https://192.168.1.1/"
                        ProxyPassReverseCookieDomain "192.168.1.1" "router.domain.com"
                </IfModule>
        </VirtualHost>
</IfModule>
