sheamus
I have an Asus AC-68U as my main router. It has been great, down in the basement.
To get a better signal upstairs, I tried an old TP Link WA701ND AP, I picket up for under $20. It was never stable, and I was constantly having to power cycle it to get devices to connect to it. (Note that the AP I had looked much older than the one on Amazon, but has same model number, not sure if they are the same, but the on amazon has a 4/5 rating, and I would have given my a 2/5 due to stability).
I have since replaced it with an old WRT310N, which I have disabled DHCP and firewall on. It has the same SSID/password, but different channels. It is extremely unreliable. Devices connected to it often say 'internet connection limited', which I think means they see the AP fine, but AP isn't able to connect to the internet.
I need to do something more reliable. The local store has a good price on a Asus RT-N53, which I am tempted to pickup. But for the same pice I could get a dedicated AP like a Ubiquiti UniFi AP (lower end one) for the same price? Though the UniFi loses the advantage of it's seamless handoff if it is is the only one... though in the future I suppose I could add to it.
Is it possible that the problem lies some where else, as I did have trouble with that TP-Link AP too.
Thoughts?
Thanks.
Thoughts?
Thanks.
