I just recently upgraded to AT&T 1GB fiber internet. I noticed that when I was using my R7000 router my speeds maxed out at 400-600 mbps. But when I plug directly into my AT&T router, I get the full speed of 900-950 mbps. So I decided I would just use the AT&T router to do all of my DHCP/Firewall/DNS stuff. Everything was working good until I found out I cannot change the DNS servers on the router. I have kids and use OPENdns. I want it to be on the router level.
So I am looking for a router that can handle the 900+ mbps WAN speeds. I need to be able to manually set the DNS records. I would also like DHCP server and firewall built into the router. I would prefer if the router did not make any noise but it will be in a closet so it isnt that big of a deal. Budget is whatever works. I do not need wireless. I already have that taken care of. I have 15-20 devices on my network.
Any suggestions?
Thank you for your time.
Any suggestions?
