I am in the process of setting up a temporary office trailer on one of our construction sites for myself and 2-3 other guys. We will be working off a hotspot for broadband access and I wanted to setup local storage (1tb or less) and printer sharing locally for cheap/easy if possible. We currently are using a sprint zing hotspot (seems to be 2-3 years old probably need to swap that out) but it has no provisions/USB male to plug into a router.
This is a 4-5 month job, trying to setup everything for $300 or less, it doesn't need to be fancy, and we are running off a generator that will only run during business hours so we will be offline and not constantly connected to the work domain.
If I were to just grab a 1tb USB 3.0 drive and run it off a USB port from a router (i run asus AC66 at home) and then also hook up the printer, am I able to add/register that share and the printer share (both off the router) with our work domain so that when everything is "on", we can see the rest of the network? All laptops/phones that would be on this network in our trailer are registered to our work domain.
The alternative would be to get a router and a small NAS (QNAP ts131 maybe, i use a 251 at home), but for what we are doing (basic local file storage, pdfs, .docx, .xlsx, etc) I feel like the router itself as the NAS attachment point should be sufficient, I just want to make sure I can avoid conflicts with our domain settings. We would use a secondary external USB drive to make a weekly backup and bring it back to the main office to sync with the servers so that we aren't syncing the whole drive over the hotspot.
Any problems with this plan?
