Dismiss Notice
Welcome To SNBForums
Router with built in free web content filtering and exclusion policy
Discussion in 'Routers' started by Chunkers, Nov 28, 2010.
  1. Chunkers
    Chunkers Occasional Visitor
    Oct 29, 2010
    39
    England
    Is there a home router which has a built in web content filtering which allows the admin to configure individual users to bypass the filters?
    The closest thing I can find at the moment is the Draytek 2820 but this does not allow exclusions and has a pesky and expensive annual charge (£60/year!)
    In a perfect world there would be a router out there which does the same kind of thing without a subscription service and has exclusions.
    I have thought about using openDNS but based on a google search it seems the average teenager can usually find a way of bypassing it.
    Cheers
    Chunks
  2. thiggins
    thiggins Mr. Easy Staff Member
    May 18, 2008
    11,191
    There are none with free content filters. If you want halfway decent content filters and don't want to build your own open source based solution, then you'll have to pay.
  3. Chunkers
    Oct 29, 2010
    39
    England
    I thought that might be the case, thanks for your reply.
    I'll have a search on here for people who have built their own solutions, I'm guessing in reality the subscription based options make economic sense if you factor in the cost of the hardware for a homebuild (and increased power consumption if its a PC based solution).
    The routers I have found which run open source soft ware tend not to have this as an option
    EDIT : Maybe I was wrong in the above statement - this might do it!
    http://packetprotector.org/index.html
    This supports DansGuardian which, from what I read, pretty much does exactly what i want. A suitable second hand router won't cost much or hopefully release 4 will support some current routers
    Cheers
    Chunks
  4. KOA
    KOA Occasional Visitor
    Nov 19, 2010
    42
    You can use either netgear's LPC or opendns itself.
  5. Chunkers
    Oct 29, 2010
    39
    England
    Thanks, I have looked at openDNS and will probably use it until Ver 4 of packet protector is released as it will hopefully support some more up to date routers.
    I don't want to replace my current router until I can get a decent one with gigabit LAN.
    Cheers
    Chunks
  6. tho3hite
    tho3hite Occasional Visitor
    Dec 4, 2010
    10
    Open source content filtering
    The open source firewall Untangle may do what you want. The lite version has very rich feature set but you would have to have a surplus Intel box to run it on.
  7. KOA
    Nov 19, 2010
    42
    I did some research, I think you can go with either of these solutions.
    1.Opendns with default firmware or custom firmware
    1A You will use opendns as your dns. Will block port 53 for all other pc on your network except the one which you will be using as admin.
    1B You will follow the instructions http://www.dd-wrt.com/wiki/index.php/OpenDNS#Intercept_DNS_Port Again blocking the port.
    2. DansGuardian with custom firmware.
    2A Use DansGuardian with ddwrt
    2B Use DansGuardian with openwrt
    With custom firmware you can use both at the same time.
    Both support a wide range of routers. Asus N-16 is decent router for running these. It has also got gigabit LAN. Also block the ports such as 9665.
  8. Chunkers
    Oct 29, 2010
    39
    England
    Just wanted to say thanks for your post, very useful info. I will definitely be having a look at the N-16.
    Cheers
    Chunks
Share This Page
