RT-AC1900p remove device from router or change lower case mac adress
BigDLondon
Hi
I'm trying to add icons to my router devices and have discovered that I put lower case into the mac address which won't allow me to put an Icon on that device . The router has kept the lower case in it's memory ? Every time I put the upper case in ,it still shows lower case when trying to add an icon.Thanks BigD
Sorry didn't work.
What firmware are you using? (don't say last one)
Aha don't click on ICON use Add / Delete button on right side.
I'm using Merlin's RT-AC68u 380.61 .The reason I'm using the icon button is I've given all the other devices icons .
If you don't want to test with "Add / Delete" button I can't help you beyond that.
I used the add / delete button and it's still in lower case. I guess a hard reset might fix that but than I have to re input everything. On client's status it shows lower case mac address.
You must edit yourself it is not automatic.
