[RT-AC3200] Some sort of clock problem?
tim
First time I have ever seen these warnings, what do they mean? Some kind of fault or NTP sync problems?
Oct 11 07:59:59 ntp: start NTP update
Oct 11 07:59:59 mDNSNetMonitor: mDNSPlatformRawTime went backwards by 49 ticks; setting correction factor to 1536720351
Oct 11 13:59:59 ntp: start NTP update
Oct 11 13:59:59 mDNSNetMonitor: mDNSPlatformRawTime went backwards by 13 ticks; setting correction factor to 1536720364
Oct 11 17:59:57 ntp: start NTP update
Oct 11 17:59:57 mDNSNetMonitor: mDNSPlatformRawTime went backwards by 61 ticks; setting correction factor to 1536720425
Oct 11 18:59:57 ntp: start NTP update
Oct 11 19:59:59 mDNSNetMonitor: mDNSPlatformRawTime went backwards by 25 ticks; setting correction factor to 1536720450
RT-AC3200 with 9.0.0.4.380_91 Beta
Oct 11 13:47:48 mDNSNetMonitor: GetLargeResourceRecord: ptr + opt->optlen > end
Oct 11 13:53:16 mDNSNetMonitor: GetLargeResourceRecord: ptr + opt->optlen > end
Oct 11 13:56:17 mDNSNetMonitor: GetLargeResourceRecord: ptr + opt->optlen > end
Oct 11 13:59:57 ntp: start NTP update
Oct 11 14:59:57 ntp: start NTP update
Oct 11 15:58:09 mDNSNetMonitor: GetLargeResourceRecord: ptr + opt->optlen > end
Oct 11 15:59:57 ntp: start NTP update
Oct 11 16:00:49 mDNSNetMonitor: GetLargeResourceRecord: ptr + opt->optlen > end
Oct 11 16:01:03 mDNSNetMonitor: GetLargeResourceRecord: ptr + opt->optlen > end
Oct 11 16:01:52 mDNSNetMonitor: GetLargeResourceRecord: ptr + opt->optlen > end
Oct 11 16:32:25 mDNSNetMonitor: GetLargeResourceRecord: ptr + opt->optlen > end
Oct 11 16:35:28 mDNSNetMonitor: GetLargeResourceRecord: ptr + opt->optlen > end
Oct 11 16:59:57 ntp: start NTP update
Oct 11 16:59:57 mDNSNetMonitor: mDNSPlatformRawTime went backwards by 10 ticks; setting correction factor to -1737060442
Oct 11 17:00:12 mDNSNetMonitor: GetLargeResourceRecord: ptr + opt->optlen > end
Oct 11 17:14:35 mDNSNetMonitor: GetLargeResourceRecord: ptr + opt->optlen > end
Thanks[/QUOTE]
I see the same thing on my RT-AC87 too, Asus beta 378.9177
Anyone have any idea about this please?
Thanks.
A quick google search show that this is a Bonjour related error
The problem was first seen on 'Oct 11 07:59:59'.
I know for a fact that no new hardware or software has been introduced around that time, or in the weeks prior.
