littlepaws
RT-AC3200 vs RT-AC88u RT-AC87U vs RT-AC68U
Which would you buy on todays market?
Or other please say reason why.......
The rt-88u looks good, would any lf these be a contender
NETGEAR Nighthawk X8 R8500
TP archer c3200
TP archer c3200
the AC68U is a nice balance of price and performance
For an all in one situation i would strike out the ac-87u for poor internal bottlenecked design. As an AP it will do fine?
You should realise that firstly you have the speeds in this order.
AC68U
AC87U
AC3100/88U
AC3200
AC5300
as for CPU speeds:
AC68U
AC87U
AC3200
AC3100/88U/5300
I just picked up an AC87U the other day. Whats the bottleneck that you are referring to?
the AC88U, no issue if you connect 100Mb/s on the extra 4 ports which many things still use (IP camers, raspbery pi, ...) but might have issue with multiple gigabit clients on the realtek switch. My main complaint is that they could've designed them better. The realtek switch on the AC88U has supports dual link RGMII and the broadcom SoC has plenty of RGMII interfaces.
1Gbps/1Gbps
Which one do you recommend that will serve well with the big connection I recently installed???
the simple answer is none , as there are no domestic routers that will currently do those speeds over the wan - lan / lan - wan interface when all router features and qos are enabled
so if you want those speeds your going to have to look at a home gateway solution , eg build your own server / router
pete
juisjuis, any AC1900 class router can achieve those speeds (900/900Mbps) without any features or options turned on, enabled or in use.
The latest routers (RT-AC3100, RT-AC88U and RT-AC5300) are the best match for Gbps ISP speeds, imo.
With the latest wireless drivers, the latest RF designs and hardware and the most resources available (dual processors, 1.4GHz speeds, double the ram and double the nvram of previous generations) along with the latest sdk's used in their firmware, they are best suited to give an acceptable performance level now and in the future.
If you can be patient for a few more months, the BRT-AC828 offers true 2Gbps speeds along with other features that will truly be a worthwhile consideration for anyone with speeds of 500Mbps and above.
Thread starter | Title | Forum | Replies | Date |
P | Replacing AC88U | Wi-Fi Buying Advice | 9 |
Welcome To SNBForums
