ACFerguson
I have had problems...
I upgraded the firmware to 3.0.0.4.188 and the problems persist.
The AC66U is set up fine and works fine as a router. However, I can't seem to get the printer to work on it. The printer is a Lexmark T520 c/w two trays (one legal, and one 500 sheet letter) and 8MB RAM.
I downloaded and ran the ASUS EZ print share utility. I followed the instructions for setting the printer up using the LPR protocol.
What happens is that the test page prints fine. But, if I try to print a subsequent test page (or anything else) I get a printer error and have to cancel the print job. If I leave it, the printer will (after a few minutes) start printing "//" at the top of each page until the 500 page tray is empty! I found this out the hard why when I left my office to go and have supper. When I came back, the printer had printed off 500 pages of...well, nothing! And, i can't reuse the paper as it causes jams because of the slight curl in the paper now. So, I've been very careful with "testing" since then. But, I still can't get this to work correctly.
And, yes, the printer works perfectly when it is connected via USB directly to the PC.
I'm hoping that someone might be able to assist me with this.
Thanks,
AC
Thanks,
AC
