RT-AC68U and Surface Pro 4
do85
Hi all and thanks for reading.
I just bought a Surface Pro 4 which has a Marvell AC network wireless card.
I'm doing some configuration on the router and the best throughput that I have is 866Mbits being clse to the router, even if, trivially copying a file from NAS it reach 31MB/s at the best (the speed is much fluctuating from 25 to 31).
On the Surface, maybe apart of firmware problems due to the newly release, I cannot set pretty anything. But what about the router? What are the best config for 5ghz and AC?
I tried to search some thread about but without success.
Thanks to anyone want help!
31 MB/s is pretty much what you should expect out of a 2x2 802.11ac client.
View attachment 4918 View attachment 4919
I'm not the expert but I think you should get better results than you have now.
Try to match these settings as much as possible.
Also, disable the wireless MAC filtering if you have it enabled. Good luck!
