RT-AC68U Portforward not showing upp
helio58
Hi, using Asus with Merlin firmware, rock solid.
I have several ports forwarded.
For two weeks ago I was going to add a new rule. But the portforward page was empty .
Reboot the router but still empty.
But I can access the ports I had forward , the problem its just I can't see in the web page.
What do you think time to change router?
There have been similar reports of entries disappearing that were caused by the router almost running out of space in NVRAM.
How can i see the NVRAM space?
In the status page shows used 130 free 120MB
Try this:
nvram show | awk '{print length(), $0 | "sort -n -r"}' | cut -d"=" -f 1 | head -n 20
https://www.snbforums.com/threads/asuswrt-merlin-378-56_2-is-now-available.27952/page-20#post-223041
I get this:
size: 65150 bytes (386 left)
3809 webdav_smb_pc
2326 client_info_tmp
1559 custom_clientlist
1161 dhcp_staticlist
624 sshd_dsskey
581 sshd_hostkey
403 rc_support
338 sshd_ecdsakey
254 wl1_maclist_x
254 wl0_maclist_x
253 wl_maclist_x
228 wl1_acs_excl_chans
227 wl_acs_excl_chans
215 vpnc_clientlist
169 vpn_client2_clientlist
168 vpn_client_clientlist
152 share_link
140 wollist
120 qos_rulelist
92 1:pa5ga2
I don't use qos no webdav.
OK Try this:
nvram unset webdav_smb_pc
nvram unset client_info_tmp
nvram unset wl_maclist_x
nvram commit
reboot
You also have a fairly large MAC filter list. Is that deliberate?
OK Try this:
nvram commit
reboot
You also have a fairly larger MAC filter list. Is that deliberate?
Thanks Colin will try when at home.
Afraid of reboot when away sometimes have to unplug the power.
The MAC filter list , I m not aware , i think its from Diversion.
Once more thank you.
The MAC filters are for the 2.4GHz and 5GHz WiFi. So check those out at Wireless > Wireless MAC Filter. They might be corrupted entries.
