RT-AC68U rebooting randomly.
HolgerDK
I have some trouble with my RT-AC68U randomly rebooting even though i have tried the latest Asus firmware and RMerlins firmware with clean setups.
I just noticed that the CPU is at 75° C/167° F, the 2,4GHz radio is at 51°C/124°F and the 5GHz is at 55° C/131° F.
Those temperatures is when the router isnt sending/receiving more than a little data.
Is that normal temperatures or could they be why the router reboots?
Normals temps, you are ok :) Mine are similars
Maybe you could post here your logs the next time.
I got a similar issues with my 68u few weeks ago and i finally found it was the "Power button".,.... too much sensitive.Just by putting a cup of coffee on the table and the router was rebooting.
Toothpick trick and no more reboots :rolleyes:
Jan  1 01:00:16 kernel: device vlan1 entered promiscuous mode
Jan  1 01:00:16 kernel: device eth0 entered promiscuous mode
Jan  1 01:00:16 kernel: device eth1 entered promiscuous mode
Jan  1 01:00:16 kernel: device eth2 entered promiscuous mode
This doesn't look normal, what F/W do you run?
AsusWRT-Merlin 378.55
That's normal, it's because of the bridge.
If you can easily reproduce it while streaming, try this via SSH:
tail -f /tmp/syslog.log
Check if you see anything unusual while the "crash/reboot" happens.
Yes i could do that if i had not RMA'ed it today. The rebooting has become worse and worse since the start and the Netflix/Youtube rebooting is new.
Ive seen one with that issue and it was a HW problem with the memory chip, i have tested with memtest and it failed.
Thank you for that info. I had a suspicion that it was hardware related but i never thought of testing the router with memtest.
