RT-AC68U unable to flash back from Merlin ( 3.0.0.4.374.39) to stock
Pdog1980
Hello,
I am hoping someone can help me. I have installed the Merlin build 3.0.0.4.374.9 to my RT-AC68U. From reading the readme file included in the zip, I should be able to restore back to the Asus firmware by simply downloading the firmware and re-flashing it back. I have tried this with the following:
RT-AC68U_3.0.0.4_378_6065-gefe6fd0.trx
RT-AC68U_3.0.0.4_378_4850-g727db45.trx
Once it gets to 100% and states completed, I have refreshed the browser and it is still on the Merlin build. After reading on these forums I have tried then performing a factory reset (from the GUI and holding the reset button on the router for 5 seconds) unfortunately it hasn't helped.
I may come back to a merlin build in the future but can anyone please provide with any help on how I can flash back to the Asus firmware please?
I have been trying for the last few hours and have been unsuccessful.
Andrew
The latest code levels require a change to the rootfs structure with a CFE update. To move from a 374 code level to ASUS 378 you have to either:
First load 376_3626 if using ASUS OEM firmware
First load the latest Merlin 378 release
After doing either of the above you'll be able to load the ASUS 378 releases.
Thank you so much for your reply. Just grabbing the:
3.0.0.4.376.3626 official, will load this and then reset it as per the article. I will report back.
Ah just reading your post again, I am currently on the merlin build. So I would need to run the latest Merlin build (378) to allow me to then use the latest Asus firmware
You can switch back and forth between Merlin and ASUS....so you could load either one. You just need a code level which supports the required CFE update.
Which means that folks probably shouldn't be tweaking their CFE files, or one can find oneself down a path with no return...
