journeyman
I have an RT-AC68U (stock firmware 3.0.0.4.376_1663) attached via a short CAT5E cable to my Motorola SB6121 cable modem. The cable modem is indicating that it sees the WAN connection as 10/100 Mbit instead of Gigabit--the WAN light is flashing orange rather than blue.
I've power-cycled both as well as tried another cable. In the past, I've had the SB6121 directly attached to my computer's Gigabit network port and it flashed blue then, so the SB6121 does detect Gigabit correctly.
Is there a setting on the AC68U that I can check or set to ensure a Gigabit connection? This isn't operationally critical, since my Internet connection is only 25Mbit/5Mbit, but I want to make sure the AC68U is working properly. Thanks for any info.
