Dean Barney
I have Cox Gigablast
When I go directly from my Cox approved modem to my pc with new ethernet cable, I achieve 800-900+ Mbps download speeds.
When I go from modem to RT-AC86U router to pc, I cannot get more than 90Mbps download speed.
RT-AC86U has most recent firmware Current Version : 3.0.0.4.384_81858-g80b1d3f
There have been no "tweaks" made to the router settings. It's a standard setup.
Should this router not connect at gigablast speeds right out of the box?
Aside from purchasing a NEW router and testing it, is there a list of settings tweaks I need to ensure are in place for the router to achieve the normal/high speeds. Are these tweaks listed anywhere, are they "current" (I'm tired of nothing matching my router interface when it comes to checking this or that in the menus based on other forum posts). Do I have a bum modem?
Thank you.
Thank you.
