RT-AC87U Access mode setup
skydriverdc6
First Im a noob here. I know very little about wireless networking, but here goes.
I bought two exact routers, the RT-AC87U and I hooked one of them up to my DSL modem which is a NetGear 7550 on Frontier internet. I also hooked the 2nd one up to the modem thinking I could have two routers on one network, but figured out this isn't a likely scenario, so I instead tried to connect router #2 to router #1 via CAT5 port #1 on router #2 to CAT5 port #1 (ports one and two on these routers say "Teaming" for some reason) on router #1. Then on router #2, I had to connect my laptop directly to the router to configure it and I chose Access Point Mode. It created a new IP for me on the same subnet as Router #1. However, when I look at the network I can't see the name I gave for SSID on the Access Point router, is that normal? I can see the SSID name
Next question, I assume that when you have an Access Point, it merely acts as an antenna for the main router and you can't really see it or connect to it?
Thanks in advance for the help!
