Hello!
I'm currently running two RT-AC87Us in a modem > RT-AC87U (as router) > RT-AC87U (as AP) setup.
I believe I'm experiencing the same problem as this member when running two RT-AC87U routers: Up to many times a day, one of the two ASUS units will crash, and the only way to fix this is to reboot said router/AP.
If the AP crashes, the only way to connect to the internet is through the router. If the router crashes, I can't access the internet at all (unless connected directly to the modem).
When one of the units crashes, I'm unable to connect to that unit - SSIDs are being broadcasted, but WiFi connection attempts result in an "unable to connect" error. If I attempt to connect via ethernet, it's either stuck in "Identifying...", or sometimes I get "Unidentified Network". I'm unable to ping the unit post-crash.
Switching the units does not help; it doesn't matter which RT-AC87U is the AP and which is the main router.
The AP's been set up with a static IP outside of the DHCP pool of the main router, and the units crash no matter what official firmware release I've used (currently testing Merlin's firmware for the first time, and experiencing the same problems on version 378.51 beta 1).
I believe this is firmware-related (unless both of my routers are faulty). Any suggestions? Will there be a fix for this?
Thanks a bunch!
Thanks a bunch!
