rt-ac87u DLNA/SAMBA problem on latest 380.63_2
airtrack
I connect my external hdd with 87u the problem is on my LG TV UH615 can't see rt-ac87u router (ext hdd) but can see the other dlna (PC, Laptop)
On PC, Laptops its working properly and detect ac87u ext hdd
but on LG TV and ps4 cannot see ac87u ext hdd but can see dlna and samba on pc and laptop
i have to restart router so both tv and ps4 can see ac87u ext hdd after using it for a while the icon seems to disappear again (both ps4 and tv) and i have to restart router every time for using dlna/samba on tv and ps4
any idea how to fix it?
Thanks, and sorry for the bad english
any help?
telnet/ssh to the router and enter the following to see if it helps
echo 0 > /sys/class/net/br0/bridge/multicast_snooping
if it works, you can add it to the init-start script to make it permanent.
thank for the help but still not working :(
I was having samba troubles a long time ago and I decided to simply restart the service once a day (in my case, at 3:55am, by creating /jffs/scripts/services-start to contain the following):
#!/bin/sh
sleep 5
# restart samba at 3:55am daily
cru a samba "55 3 * * * service restart_samba"
Maybe that would help.....
#!/bin/sh
sleep 5
Thanks, i wish Merlin could fix this :(
Yours seems to be an isolated Samba problem.
If the smb restart works, then this is a good working solution for you.
Have you had a look at the log files Samba creates for clues?
/var/
- log.nmbd
- log.smbd
The log file /var/log.samba is per default set to a log level of 0, so no entries in that:
- log.samba
But you can enable it with:
Create the file /jffs/scripts/smb.postconf
Add these entries to it:
#!/bin/sh
CONFIG=$1
source /usr/sbin/helper.sh
pc_replace "log level = 0" "log level = 3" $CONFIG
Make the file executable:
chmod a+rx /jffs/scripts/*
Make sure it has the correct unix EOL:
dos2unix /jffs/scripts/smb.postconf
Then click 'Apply' in the WebUI in 'Network Place (Samba)', this restarts the necessary services and applies the change.
If you open up /etc/smb.conf it will show:
log level = 3
Then do some tests and check the log files for errors for your TV device.
/var/
- log.nmbd
- log.smbd
- log.samba
#!/bin/sh
CONFIG=$1
log level = 3
I appreciate for your help but still not working.
Its not just LG smart TV , But ps4 in DLNA too (PC and Ps4 can see DLNA on PC only 87u attach with ext hdd)
PC and all smart phone are working fine
here is my smb
[global]
workgroup = WORKGROUP
netbios name = RT-AC87U
server string = RT-AC87U
unix charset = UTF8
display charset = UTF8
log file = /var/log.samba
log level = 3
max log size = 5
security = USER
guest ok = no
map to guest = Bad User
encrypt passwords = yes
pam password change = no
null passwords = yes
max protocol = SMB2
passdb backend = smbpasswd
smb encrypt = disabled
smb passwd file = /etc/samba/smbpasswd
force directory mode = 0777
force create mode = 0777
max connections = 5
obey pam restrictions = no
disable spoolss = yes
host msdfs = no
strict allocate = No
bind interfaces only = yes
interfaces = lo br0 192.168.1.1/255.255.255.0
use sendfile = yes
wins support = yes
map archive = no
map hidden = no
map read only = no
map system = no
store dos attributes = yes
dos filemode = yes
oplocks = yes
level2 oplocks = yes
kernel oplocks = no
wide links = no
[Download2]
comment = BACKUP's Download2 in WD 0528AS External
path = /tmp/mnt/BACKUP/Download2
dos filetimes = yes
fake directory create times = yes
valid users = admin
invalid users =
read list = admin
write list = admin
[load]
comment = BACKUP's load in WD 0528AS External
path = /tmp/mnt/BACKUP/load
dos filetimes = yes
valid users = admin
invalid users =
read list = admin
write list = admin
Increasing the log level does not magically solve the problem?
I wonder what the heck these programmers were thinking when they added that option.
But maybe you could use that fck up to your advantage and look at the files it creates.
yes, right now im using universal media server on my pc and add ac87u as a file source which is stupid because i had to run my pc 24/7 or reset the router when i need to use it without pc.
I am lost.
