RT-AC88U issues with wireless Authentication method selection.
kman117
Hi The authentication method under wireless keeps resetting to open system after WAP 2 personal is requires and legacy, n only also keep resetting to default after applied.
Flash the latest firmware again and webUI Restore w/Initialize to reset it before you configure it from scratch. If that doesn't fix it, there may be a hardware issue.
OE
OE
Hi I attached an image of the issue Belo
I am using the latest Beta4 I also attached an image below
