Jan 18 11:14:07 openvpn[10677]: Current Parameter Settings:
Jan 18 11:14:07 openvpn[10677]: config = 'config.ovpn'
Jan 18 11:14:07 openvpn[10677]: mode = 0
Jan 18 11:14:07 openvpn[10677]: persist_config = DISABLED
Jan 18 11:14:07 openvpn[10677]: persist_mode = 1
Jan 18 11:14:07 openvpn[10677]: NOTE: --mute triggered...
Jan 18 11:14:07 openvpn[10677]: 217 variation(s) on previous 5 message(s) suppressed by --mute
Jan 18 11:14:07 openvpn[10677]: OpenVPN 2.3.14 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Dec 16 2016
Jan 18 11:14:07 openvpn[10677]: library versions: OpenSSL 1.0.2j 26 Sep 2016, LZO 2.08
Jan 18 11:14:07 openvpn[10679]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Jan 18 11:14:07 openvpn[10679]: Control Channel Authentication: using 'static.key' as a OpenVPN static key file
Jan 18 11:14:07 openvpn[10679]: Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Jan 18 11:14:07 openvpn[10679]: Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Jan 18 11:14:07 openvpn[10679]: LZO compression initialized
Jan 18 11:14:07 openvpn[10679]: Control Channel MTU parms [ L:1562 D:1184 EF:66 EB:0 ET:0 EL:3 ]
Jan 18 11:14:07 openvpn[10679]: Socket Buffers: R=[122880->122880] S=[122880->122880]
Jan 18 11:14:07 openvpn[10679]: Data Channel MTU parms [ L:1562 D:1390 EF:62 EB:143 ET:0 EL:3 AF:3/1 ]
Jan 18 11:14:07 openvpn[10679]: Fragmentation MTU parms [ L:1562 D:1390 EF:61 EB:143 ET:1 EL:3 AF:3/1 ]
Jan 18 11:14:07 openvpn[10679]: Local Options String: 'V4,dev-type tun,link-mtu 1562,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client'
Jan 18 11:14:07 openvpn[10679]: Expected Remote Options String: 'V4,dev-type tun,link-mtu 1562,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 0,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-server'
Jan 18 11:14:07 openvpn[10679]: Local Options hash (VER=V4): 'e05aa1c5'
Jan 18 11:14:07 openvpn[10679]: Expected Remote Options hash (VER=V4): '0088baee'
Jan 18 11:14:07 openvpn[10679]: UDPv4 link local: [undef]
Jan 18 11:14:07 openvpn[10679]: UDPv4 link remote: [AF_INET]xx.xx.xx.xxx:1194
Jan 18 11:14:37 openvpn[10679]: TLS Error: TLS key negotiation failed to occur within 30 seconds (check your network connectivity)
Jan 18 11:14:37 openvpn[10679]: TLS Error: TLS handshake failed
Jan 18 11:14:37 openvpn[10679]: TCP/UDP: Closing socket
Jan 18 11:14:37 openvpn[10679]: SIGUSR1[soft,tls-error] received, process restarting
Jan 18 11:14:37 openvpn[10679]: Restart pause, 2 second(s)
Jan 18 11:14:39 openvpn[10679]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Jan 18 11:14:39 openvpn[10679]: Re-using SSL/TLS context
Jan 18 11:14:39 openvpn[10679]: LZO compression initialized
Jan 18 11:14:39 openvpn[10679]: Control Channel MTU parms [ L:1562 D:1184 EF:66 EB:0 ET:0 EL:3 ]
Jan 18 11:14:39 openvpn[10679]: Socket Buffers: R=[122880->122880] S=[122880->122880]
Jan 18 11:14:39 openvpn[10679]: Data Channel MTU parms [ L:1562 D:1390 EF:62 EB:143 ET:0 EL:3 AF:3/1 ]
Jan 18 11:14:39 openvpn[10679]: Fragmentation MTU parms [ L:1562 D:1390 EF:61 EB:143 ET:1 EL:3 AF:3/1 ]
Jan 18 11:14:39 openvpn[10679]: Local Options String: 'V4,dev-type tun,link-mtu 1562,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client'
Jan 18 11:14:39 openvpn[10679]: Expected Remote Options String: 'V4,dev-type tun,link-mtu 1562,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 0,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-server'
Jan 18 11:14:39 openvpn[10679]: Local Options hash (VER=V4): 'e05aa1c5'
Jan 18 11:14:39 openvpn[10679]: Expected Remote Options hash (VER=V4): '0088baee'
Jan 18 11:14:39 openvpn[10679]: UDPv4 link local: [undef]
Jan 18 11:14:39 openvpn[10679]: UDPv4 link remote: [AF_INET]68.71.55.123:1194
Jan 18 11:15:01 (restart_wan.sh): 10853 START VERIFICA CONNESSIONE
Jan 18 11:15:09 openvpn[10679]: TLS Error: TLS key negotiation failed to occur within 30 seconds (check your network connectivity)
Jan 18 11:15:09 openvpn[10679]: TLS Error: TLS handshake failed
Jan 18 11:15:09 openvpn[10679]: TCP/UDP: Closing socket
Jan 18 11:15:09 openvpn[10679]: SIGUSR1[soft,tls-error] received, process restarting
Jan 18 11:15:09 openvpn[10679]: Restart pause, 2 second(s)
Jan 18 11:15:11 openvpn[10679]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Jan 18 11:15:11 openvpn[10679]: Re-using SSL/TLS context
Jan 18 11:15:11 openvpn[10679]: LZO compression initialized
Jan 18 11:15:11 openvpn[10679]: Control Channel MTU parms [ L:1562 D:1184 EF:66 EB:0 ET:0 EL:3 ]
Jan 18 11:15:11 openvpn[10679]: Socket Buffers: R=[122880->122880] S=[122880->122880]
Jan 18 11:15:11 openvpn[10679]: Data Channel MTU parms [ L:1562 D:1390 EF:62 EB:143 ET:0 EL:3 AF:3/1 ]
Jan 18 11:15:11 openvpn[10679]: Fragmentation MTU parms [ L:1562 D:1390 EF:61 EB:143 ET:1 EL:3 AF:3/1 ]
Jan 18 11:15:11 openvpn[10679]: Local Options String: 'V4,dev-type tun,link-mtu 1562,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client'
Jan 18 11:15:11 openvpn[10679]: Expected Remote Options String: 'V4,dev-type tun,link-mtu 1562,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 0,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-server'
Jan 18 11:15:11 openvpn[10679]: Local Options hash (VER=V4): 'e05aa1c5'
Jan 18 11:15:11 openvpn[10679]: Expected Remote Options hash (VER=V4): '0088baee'
Jan 18 11:15:11 openvpn[10679]: UDPv4 link local: [undef]
Jan 18 11:15:11 openvpn[10679]: UDPv4 link remote: [AF_INET]xxx.xxx.xxx.xxx:1194
Jan 18 11:15:41 openvpn[10679]: TLS Error: TLS key negotiation failed to occur within 30 seconds (check your network connectivity)
Jan 18 11:15:41 openvpn[10679]: TLS Error: TLS handshake failed
Jan 18 11:15:41 openvpn[10679]: TCP/UDP: Closing socket
Jan 18 11:15:41 openvpn[10679]: SIGUSR1[soft,tls-error] received, process restarting
Jan 18 11:15:41 openvpn[10679]: Restart pause, 2 second(s)
Jan 18 11:15:43 openvpn[10679]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Jan 18 11:15:43 openvpn[10679]: Re-using SSL/TLS context
Jan 18 11:15:43 openvpn[10679]: LZO compression initialized
Jan 18 11:15:43 openvpn[10679]: Control Channel MTU parms [ L:1562 D:1184 EF:66 EB:0 ET:0 EL:3 ]
Jan 18 11:15:43 openvpn[10679]: Socket Buffers: R=[122880->122880] S=[122880->122880]
Jan 18 11:15:43 openvpn[10679]: Data Channel MTU parms [ L:1562 D:1390 EF:62 EB:143 ET:0 EL:3 AF:3/1 ]
Jan 18 11:15:43 openvpn[10679]: Fragmentation MTU parms [ L:1562 D:1390 EF:61 EB:143 ET:1 EL:3 AF:3/1 ]
Jan 18 11:15:43 openvpn[10679]: Local Options String: 'V4,dev-type tun,link-mtu 1562,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client'
Jan 18 11:15:43 openvpn[10679]: Expected Remote Options String: 'V4,dev-type tun,link-mtu 1562,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 0,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-server'
Jan 18 11:15:43 openvpn[10679]: Local Options hash (VER=V4): 'e05aa1c5'
Jan 18 11:15:43 openvpn[10679]: Expected Remote Options hash (VER=V4): '0088baee'
Jan 18 11:15:43 openvpn[10679]: UDPv4 link local: [undef]
Jan 18 11:15:43 openvpn[10679]: UDPv4 link remote: [AF_INET]xxx.xxx.xxx.xxx:1194
