RT-AX86U firmware 386.3 beta 3 VPN does not work
AdamW
installed the latest firmware because I have such a symptom I can not connect to the VPN server on this router, i.e. when I connect from one computer is ok but if I want to connect from a second computer at the same time, I disconnect on the first one
Did VPN work fine on 386.2? If yes, try setting up the VPN from scratch, export the new config-file and set-up openvpn connect again.
Is that Merlin firmware?
If so there is a sub-forum for his firmware.
If you use certificate-based authentication (instead of username-based), each certificate must have a unique Common Name.
You can add "duplicate-cn" to your config to allow more than one client using same cert.
if you can write exactly where to make such an entry, I just have to enter duplicate-cn
Write it in your custom configuration box in used client.
