RT-AX86U - Gear Accelerator slowing down speedtest
vessosa
Hello,
After changing some parameters in my router (adding my PC to Gear Accelerator, enabling Traffic Analyzer, enabling AiProtection and "securing" all 15 features that it suggest) I saw that my speed test was reduced to lower than half of my internet speed.
After undoing everything step by step I could see that the problem was Gear Accelerator..
Have you tried to add your PC to the Gear Accelerator feature and checked your speed after?
I'm using a RT-AX86U.
I did that, same recommendation when enabling Traffic Analyzer and AiProtection?
Traffic Analyzer should have no impact on speed. AiProtect might but it is an extra protection layer that might just save you a lot of trouble cleaning up your network devices.
AiProtect has no effect or almost to point of non determinable as extra layer of security is well worth it, I always run it. Besides, you paid for it, literally, with the router as its part of the contract agreement between Asus and MicroTrend is the contract to have it built into their routers for life
