iwannacrii
Hi All,
I have recently upgraded to 250mbps DL / 100mbps UL
For a time I was getting great speeds but all of a sudden my download speed will not go above 95mbps.
I tried a direct connection with my laptop using the same ethernet cable that was going to my WAN port and i was able to achieve around 257mbps DL.
For some reason my router is auto-negotiating at 100mbps & not 1Gbps
I have factory reset, tried a different ethernet cable thats coming from the Fibre box outside
I have tried the normal Asus Firmware & Merlins firmware but same result
Not sure what im doing wrong here as my ISP's end is definitely okay but the issue seems to be my router not correctly negotiating speed.
Any pointers guys? (Also apologies if this is not the section to post this)
Thanks!
Thanks!
