RT-AX88U random wifi drops
gekko44
Hi guys,
From time to time my router (running latest merlin fw - btw @RMerlin thanks!) drops wifi connections - literally disables all wifi networks (but still accessible through lan) and after (ca.) 30-60 seconds wifi backs again. Any help? DFS is switched off. Log attached.
Oh, btw - in the log I got incorrect (May?) date logged - don't know where it comes from :-(
Any help is greatly appreciated
  • syslog.txt
  • syslog.txt
Hi @RMerlin it took me a while but has to say that none of the following tips worked :(
Quick addendum, as I lack the time to maintain the original post:
In newer routers, if you experience wireless stability issues then it's recommended that you disable the following options:
  • MU-MIMO (some hardware revisions have non-functional/unreliable implementations)
  • Airtime Fairness (causes connectivity issues for various devices, including wireless printers)
  • Universal Beamforming (non-standard, might cause compatibility issues with some clients)
What can I do now? Can You please help me out?
You may want to try the suggestions below to see if you can get your router back to a good/known state and let your router use the expected defaults of the firmware currently running on it.
I suggest you use RMerlin firmware 386.1 Beta 4 or later before doing the procedures below.
Fully Reset Router and Network
New M&M 2020
Further notes and suggestions in the link below.
L&LD | SmallNetBuilder Forums
