Dismiss Notice
Welcome To SNBForums
RT-N66U DHCP Relay
Discussion in 'ASUS N Routers & Adapters' started by Lactose The Intolerant, Jan 16, 2013.
  1. Lactose The Intolerant
    Lactose The Intolerant New Around Here
    Jan 16, 2013
    8
    Hello, new N66 owner. I am wondering if it is possible to setup the router to relay DHCP from my Netgear firewall. My previous wireless router allowed this but I am not seeing where it is possible with the Asus.
    I would like to avoid switching to AP mode if possible as when I setup that way my speeds were terrible. Thank you for your time and consideration.
  2. Lactose The Intolerant
    Jan 16, 2013
    8
    If it is not possible to perform DHCP relay is it possible to speed up the AP mode? Speeds drop to one half on speed when running in router mode. Hardwire connection still is fine when in AP mode but wireless is very slow.
    Thank you again.
  3. srinivasvaradaraj
    srinivasvaradaraj Regular Contributor
    Feb 26, 2012
    75
    Beaumont, TX, USA
    To accomplish what your trying to do,
    1) Setup the LAN part of your ASUS router with a fixed IP outside the DHCP scope of your Netgear router. Make sure your netgear router is configured as the gateway on the router and match the netmask . So your asus is just another statically addressed client on the network.
    2) Connect from one of the LAN ports on your ASUS to one of the LAN ports on the netgear router.
    3) make sure you can ping both IP address of the asus router and your netgear gateway so you don't lose connections
    4) Turn off your DHCP server on the asus router and leave it in router mode and enjoy.
Share This Page
