ChilliBYTE
My RT-N66U has started to show it's age. The unit is starting to overheat with avg temps between 60-65 deg C. The wireless (low bandwidth stuff) seems to be ok, but as soon as I start to stream a movie, or the wireless camera is switched on, the unit seems to really overheat and shuts down and then restarts. Sometimes it gets stuck in a boot loop and I have to switch it off for 30 mins and then only will it start up.
In December, I was on the latest Merlin fw and have kept up since, but the problem persists.
The unit is out of warranty now also.
I had a black out and I think that when the power came back on there was a surge as the power supply had died. I am not sure if that would have caused a surge inside the device as well and possibly damaged the hardware.
I read in these forums that the voltage regulator can get damaged, I am not sure how I could check this.
Any advice would be appreciated.
