InverseParanoid
Just got the RT-N66 yesterday and set the router up with the latest Merlin firmware. However, I can't seem to get the router to properly connect to the phone so that other device's can connect to the internet through it.
I tried 2 different Merlin firmwares and 2 different stock firmwares, and none of them seemed to allow the router to connect to the internet through the phone. It would recognize it as a Samsung Android but whenever I would try to activate tethering on the phone it would "uncheck" the box or grey it out, indicating that it wasn't making a successful connection.
Right now I have the phone connected to an old laptop via USB tether and then I bridged the connection to the ethernet port and hooked the laptop up directly to the router's WAN port. Everything works perfectly this way, but I have to have the laptop on 24/7 in order for the router to have internet.
Does anyone know of a reliable way to connect the phone directly to the router and let the network use its internet connection? I am willing to install Tomato or DD-WRT if either can offer the solution. Or maybe even return the router and get one that's compatible with Open-WRT (not sure if new accounts are allowed to link here, but if you google "Open-WRT android tether" a how-to guide is the first thing to pop up, but alas the RT-N66 router is not Open-WRT compatible).
Any ideas? My SO doesn't seem to happy about having a laptop running 24/7 under the couch.
Thanks,
Josh
Thanks,
Josh
