Praveen Johri
Hello,
I just flashed the firmware to be able to use selective policy based openvpn client connection.
I noticed that the vpn username after applying the settings comes back to router admin user name and password, is this a bug? in the instance if the connection is broken and it tries to connect again it will use the default admin user but not the vpn user..this is a problem. can this be fixed?
Also, once the connection is established I see this IP/Routing conflict as status but in system log connection appears fine, another bug??
My purpose to use Merlin firmware is defeated if I have to connect everytime manually to update correct user name, does anyone else have this issue?
Is it possible to do policies not just based on IPor hosts but also include ports? I want to route only specific applications I am using on my server through VPN for rest normal connection is needed. - is this achievable, feature request?
-Praveen
-Praveen
