The main use of my RT-AX68U besides providing a fast wifi connection is to be able to have a shared drive between two computers and few other devices.
However since I started using this router for a shared network drive it's being a pain with constant instabilities (Windows explorer freezes, the PC gets unresponsive, open application using network files aborts and I lose my unsaved job).
Attached my UI screen and smb.conf.
Any help will be appreciated. I'm using SMBv2 only (please don't suggest me to add support for SMBv1; it's an insecure and inneficcient protocol).
Below samba.log and nmbd.log (smbd.log doesn't have anything logged recently)
admin@RT-AX68U-F300:/var/log# cat samba.log
[2021/09/24 09:05:44.295688, 0] smbd/negprot.c:706(reply_negprot)
No protocol supported !
[2021/09/24 09:05:45.426740, 0] smbd/negprot.c:706(reply_negprot)
[2021/09/24 11:49:09.478335, 0] smbd/negprot.c:706(reply_negprot)
[2021/09/24 11:49:09.488205, 0] smbd/negprot.c:706(reply_negprot)
[2021/09/24 11:51:53.854850, 0] lib/fault.c:47(fault_report)
[2021/09/24 11:51:53.856264, 0] lib/fault.c:48(fault_report)
INTERNAL ERROR: Signal 11 in pid 31644 (3.6.25)
Please read the Trouble-Shooting section of the Samba3-HOWTO
[2021/09/24 11:51:53.856434, 0] lib/fault.c:50(fault_report)
From: http://www.samba.org/samba/docs/Samba3-HOWTO.pdf
[2021/09/24 11:51:53.856525, 0] lib/fault.c:51(fault_report)
[2021/09/24 11:51:53.856632, 0] lib/util.c:1117(smb_panic)
PANIC (pid 31644): internal error
[2021/09/24 11:51:53.859937, 0] lib/util.c:1221(log_stack_trace)
BACKTRACE: 0 stack frames:
[2021/09/24 11:51:53.860065, 0] lib/fault.c:345(dump_core)
Exiting on internal error (core file administratively disabled)
nmbd.log looks like this:
[2021/09/24 11:06:34, 0] nmbd/nmbd_browsesync.c:351(find_domain_master_name_query_fail)
find_domain_master_name_query_fail:
Unable to find the Domain Master Browser name WORKGROUP<1b> for the workgroup WORKGROUP.
Unable to sync browse lists in this workgroup.
[2021/09/24 11:21:44, 0] nmbd/nmbd_browsesync.c:351(find_domain_master_name_query_fail)
[2021/09/24 11:36:34, 0] nmbd/nmbd_browsesync.c:351(find_domain_master_name_query_fail)
[2021/09/24 11:51:33, 0] nmbd/nmbd_browsesync.c:351(find_domain_master_name_query_fail)
