Sandisk Extreme USB3 flash not detected in Asus rt-ac68-u
Pedro Sobral
My USB3 flash is not detected in the usb3 port but its fine in the usb2 port.
firmware 380.57, already disabled "reducing USB3 interference"...
This is from the log:
Jun 29 17:16:35 kernel: usb 2-1: new high speed USB device using ehci_hcd and address 60
Jun 29 17:16:35 kernel: hub 2-0:1.0: unable to enumerate USB device on port 1
Jun 29 17:16:35 kernel: hub 3-0:1.0: unable to enumerate USB device on port 1
Jun 29 17:16:36 kernel: hub 2-0:1.0: unable to enumerate USB device on port 1
Jun 29 17:16:37 kernel: hub 2-0:1.0: unable to enumerate USB device on port 1
Any ideas?
BR
Pedro
Disable the USB 3.0 interference option under WIreless 2.4 GHz -> Professional.
Thanks for the reply.
I'm on a MAC. Installed tuxera NTFS, formatted the drive as NTFS. No luck.
Jun 29 23:30:53 kernel: usb 2-1: new high speed USB device using ehci_hcd and address 104
Jun 29 23:30:53 kernel: hub 2-0:1.0: unable to enumerate USB device on port 1
Jun 29 23:30:54 kernel: hub 3-0:1.0: unable to enumerate USB device on port 1
Jun 29 23:30:54 kernel: hub 2-0:1.0: unable to enumerate USB device on port 1
BR
Pedro
You can format the drive to FAT32 under OS X. It's the "MS-DOS" or similarly named option in disk utility.
Are you plugging it directly into the port, or using an extender cable?
Hello,
Directly into the port.
By the way... the port is working just fine with usb2 devices.
I bought this because I also need usb3 speeds on file sharing. I was not expecting this... :-(
Can you give me some advise on a USB3 2.5'' disk enclosure that is working?
Thanks!
BR
Pedro
I have an external USB 3.0 hard drive that was working in my Asus AC68U but stopped recently. It's got a 4tb drive formatted ext3 but it always worked and suddenly didn't, it wasn't being detected at all. On a whim I plugged it into my USB 2 port of my Asus and it was suddenly it was detected and working fine. I'm curious what would happen if you plug your device into the USB2 port of your router?
BobMCT cifs to USB3.0 external hdd seems to have stopped working Asuswrt-Merlin 2
