As a retired paramedic, I do a bit of volunteer work near the US/Canadian border and need a data solution for my vehicle/RV that covers the following:
Primary Goals
A couple notes:
Much of the system is already in, the central remaining item is the cellular gateway - currently looking at the PepWave BR1-ENT, which has dual sims, cell jack, good support, etc.
While an DC-AC inverter is installed, the network will be running off 12v dc.
Here is the layout:
Thoughts and comments much appreciated!
Primary Goals
- Parked with ability to physically 'jack in'.
- Parked / locally mobile with WiFi access via 2.4 GHz Ubiquity Nano (directional) or Rocket (Omni MIMO) (have both) - When available
- Connection via US cellular network - When available
- Connection via Canadian Cellular Network - When available
- Failover between WiFi (effectively WAN), US Cellular, and Canadian Cellular
- GPS logging and poling from remote location
- Serial interface for basic vehicle diagnostics (battery voltage, temperature)
- While failover is a goal, teaming/bonding is not required.
A couple notes:
Here is the layout:
