script to unmount and remount HD
sabot105mm
script to unmount and remount HD (Solved)
could someone guide me on how to write a script to mount my HDD at 12pm and unmount it at 3am.
Adding jobs to the crontab
Here we go - hope it helps and there are not to many typos in the text... :rolleyes:
With kind regards
Joe :cool:
Prerequesits:
  • Enable and format the Persistent JFFS2 partition on the router under Administration / System.
  • Make yourself familiar with Telnet (you can use PuTTY or the default Windows telnet command).
  • Make yourself comfortable with the vi editor (or install Entware and nano for a more comfortable editor).
a) Find the USB attached HDD:
chief@RT-N66U:/tmp/home/root# fdisk -l
Disk /dev/sda: 750.1 GB, 750156374016 bytes
255 heads, 63 sectors/track, 91201 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
   Device Boot      Start         End      Blocks  Id System
/dev/sda2              66          73       64260  82 Linux swap
/dev/sda4             139       91201   731463547+ 83 Linux
Disk /dev/sdb: 1018 MB, 1018691584 bytes
30 heads, 29 sectors/track, 2286 cylinders
Units = cylinders of 870 * 512 = 445440 bytes
/dev/sdb1               1        2287      994691+  6 FAT16
Looking on the fdisk output my HDD is mapped to the device /dev/sda.
The partion to be mounted and unmounted is mapped to the device name /dev/sda4
To be able to remove the HDD in my case the Linux swap also need to be stopped.
Of course you may have different device names!
Now we need to know the standard mount points:
chief@RT-N66U:/tmp/home/root# mount
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro)
proc on /proc type proc (rw)
tmpfs on /tmp type tmpfs (rw)
devfs on /dev type tmpfs (rw,noatime)
sysfs on /sys type sysfs (rw)
devpts on /dev/pts type devpts (rw)
/dev/mtdblock4 on /jffs type jffs2 (rw,noatime)
usbfs on /proc/bus/usb type usbfs (rw)
/dev/sda4 on /tmp/mnt/Data type ext3 (rw,nodev,noatime,data=ordered)
/dev/sdb1 on /tmp/mnt/sdcard type ext3 (rw,nodev,noatime,data=ordered
The Data partition (/dev/sda4) is by default mounted to the mount point /tmp/mnt/Data.
The file systems type is ext3 and the mount options are rw,nodev,noatime,data=ordered.
b) Unmount the HDD:
The test the unmount command:
umount /tmp/mnt/Data
Create a unmount script:
nano (or vi) /jffs/scripts/unmount-hdd.sh
Enter the text:
#!/bin/sh
/bin/umount /tmp/mnt/Data
For nano type: "Ctrl-O" plus "Enter" to save and exit
c) Mount the HDD:
The test the mount command:
/bin/mount -t ext3 -o rw,nodev,noatime,data=ordered /dev/sda4 /tmp/mnt/Data
Remember to use your specific device path and mount point!
Creat the mount script:
nano (or vi) /jffs/scripts/mount-hdd.sh
Enter the text:
#!/bin/sh
d) Elaborate on cron jobs and cru:
The full syntax of the cron jobs can be found in the cron wiki page
What we need is the syntax for adding a cron job to mount the HDD at 12:00pm (and 3:00am), every day:
chief@RT-N66U:/jffs/scripts# cru a mount "0 12 * * * /jffs/scripts/mount-hdd.sh"
chief@RT-N66U:/jffs/scripts# cru a unmount "0 3 * * * /jffs/scripts/unmount-hdd.sh"
Let's check the if the cru add was a success:
chief@RT-N66U:/jffs/scripts# cru l
0 12 * * * /jffs/scripts/mount-hdd.sh #mount#
0 3 * * * /jffs/scripts/unmount-hdd.sh #unmount#
Let's delete the mount cru:
chief@RT-N66U:/jffs/scripts# cru d mount
chief@RT-N66U:/jffs/scripts# cru d unmount
e) Create a cron setup script:
Add the script to jffs to execute the cron scheduling on each boot of the router. Details on the different user scripts can be found in Merlin's wiki page.
nano (or vi) /jffs/scripts/services-start
Enter the text:
[B]#!/bin/sh
/usr/bin/logger -t START_$(basename $0) "started [$@]"  [/B]# logs the start of the script into the syslog.log
[B]SCRLOG=/tmp/$(basename $0).log  [/B]# creates a log for this script (services-start.log)
[B]touch $SCRLOG  [/B]# creates the log file
[B]echo "START_$(basename $0) started [$@]" >> $SCRLOG  [/B]# writes the start into the log
[B]/usr/sbin/cru a mount "0 12 * * 0 /jffs/scripts/mount-hdd.sh" >> $SCRLOG  [/B]# adds the mount cron job
[B]/usr/sbin/cru a unmount "0 3 * * 0 /jffs/scripts/unmount-hdd.sh" >> $SCRLOG  [/B]# adds the unmount cron job
[B]if [ "$?" -ne 0 ]  [/B]# checks for error
[B]then
echo "Error in services-start execution! Script: $0" >> $SCRLOG  [/B]# writes error message into the log file
[B]exit $?  [/B]# exit with error code
[B]else
echo "Services-start execution OK. Script: $0" >> $SCRLOG[/B]  # writes OK (if no error) into the log file
[B]exit 0  [/B]# exit with OK code
[B]fi[/B]
f) Make all scripts in JFFS executable:
chmod a+rx /jffs/scripts/*
g) Reboot the router to verify that everything is working
Check the syslog.log for start of the user script:
chief@RT-N66U:/jffs/scripts# more /tmp/syslog.log | grep started
Jan  1 01:00:13 START_services-start: started []
Check the services-start.log for messages:
chief@RT-N66U:/jffs/scripts# more /tmp/services-start.log
START_services-start started []
Services-start execution OK. Script: /jffs/scripts/services-start
Check cru for the cron events:
cru l
h) Have fun with your automated enabled / disabled HDD!
Thanks for this setup I like it but I'm having trouble remounting the hd.
mounting /dev/sda1 on /tmp/mnt/HD failed: No such device
even though it says sda1 dosnt exist, that's what it used to mount it when I turned the router on.
Also I have a question. I set the sda interface to sleep after 10 minutes will it still sleep if its unmounted?
/dev/sdb1 on /tmp/mnt/USB type ext2 (rw,nodev,noatime)
/dev/sda1 on /tmp/mnt/HD type ufsd (rw,nodev,noatime,nls=utf8,fmask=0,dmask=0,force)
Can you also post the full mount command you used?
With kind regards
Joe :cool:
Probably your HDD isn't anymore /dev/sda.
Check this with:
# fdisk -l
To avoid this kind of problems (device name change), you can use UUID to mount the partitions.
UUIDs are always unique.
To find a UUID of your partitions do:
# blkid
Should look something like this:
# blkid
/dev/sda2: LABEL="Seagate2TB" UUID="078f4b9d-9266-4188-97cd-54987910bf33"
/dev/sda1: UUID="6be4cca1-622d-4753-afd3-35f4833ac4cd"
Find your UUIDs and mount every partition with:
mount -t ext3 -o rw,nodev,noatime,data=ordered UUID="Your_UUID_Here" /tmp/mnt/Data
Also for swap is UUID useful:
swapon UUID="Your_UUID_Here"
Ok so I used the uuid to mount when I do I get this
mount -t nfsd -o rw,nodev,noatime,nls=utf8,fmask=0,dmask=0,force
UUID="AAEE24F8EE24BF07" tmp/mnt/HD
mounting /dev/sda1 on /tmp/mnt/HD failed: No such file or directory
got it
mount -t nfsd -o rw,nodev,noatime,nls=utf8,fmask=0,dmask=0,force UUID="AAEE24F8EE24BF07" /tmp/mnt/HD
but when i go to the routers homepage it says the HD has 0 space left? and alos the smb shares arnt found for that HD
sorry it took so long. i went into the console and typed what you said after mounting the hd.
Filesystem                Size      Used Available Use% Mounted on
/dev/root                22.5M     22.5M         0 100% /
tmpfs                   117.1M      2.6M    114.6M   2% /tmp
devfs                   117.1M         0    117.1M   0% /dev
/dev/mtdblock4            7.9M    532.0K      7.4M   7% /jffs
/dev/sdb1                 1.8G     15.0M      1.7G   1% /tmp/mnt/USB
[2013/03/03 11:29:27] minissdp.c:680: info: SSDP M-SEARCH from 10.9.10.5:49457 ST: urn:schemas-upnp-org:device:InternetGatewayDevice:1, MX: 3, MAN: "ssdp:discover"
[2013/03/03 11:30:00] minissdp.c:680: info: SSDP M-SEARCH from 10.9.10.5:49457 ST: urn:schemas-upnp-org:device:InternetGatewayDevice:1, MX: 3, MAN: "ssdp:discover"
[2013/03/03 11:30:33] minissdp.c:680: info: SSDP M-SEARCH from 10.9.10.5:49457 ST: urn:schemas-upnp-org:device:InternetGatewayDevice:1, MX: 3, MAN: "ssdp:discover"
/dev/sda1 on /tmp/mnt/HD type nfsd (rw,nodev,noatime)
So, your /dev/sda1 is mounted on /tmp/mnt/HD but isn't shown by df command.
This mean that FileSystem is corrupted.
Unmount it and run fsck:
# e2fsck -fv /dev/sda1
Will take some time to finish.
After that mount it again and check it.
Hmm, do you really recommend to us e2fsck for checking a NTFS formatted drive??? :confused:
I would suggest to connect the HDD to a Windows PC and to run the check there. :)
With kind regards
Joe :cool:
