Dismiss Notice
Welcome To SNBForums
Service Life?
Discussion in 'ASUS N Routers & Adapters' started by Radiator, Feb 26, 2013.
  1. Radiator
    Radiator Occasional Visitor
    Feb 26, 2013
    11
    What kind of lifespan can I reasonably expect to get out of one of these n900 routers since they apparently run hot?
  2. thiggins
    thiggins Mr. Easy Staff Member
    May 18, 2008
    10,964
    Heat isn't necessarily the primary failure mechanism. Power supplies also tend to fail prematurely.
    But there really isn't any fact-based way to answer your question without access to manufacturer failure information.
  3. RMerlin
    RMerlin Part of the Furniture
    Apr 14, 2012
    19,338
    Canada
    Those temperatures are fairly common these days for high end routers. My former WRT310N was actually running hotter, due to its more compact design.
  4. Radiator
    Feb 26, 2013
    11
    Ballpark guesstimate? 5yrs? More? Less?
    Anyone had one in operation for an extended period of time?
  5. joegreat
    joegreat Very Senior Member
    Jan 9, 2013
    1,041
    Vienna, Austria
    Yep, something between one day and 5 years is realistic! :eek: :rolleyes: :) :D
  6. RMerlin
    Apr 14, 2012
    19,338
    Canada
    Hard to tell since the router has only been on the market for a year :)
  7. ChrisR
    ChrisR Regular Contributor
    Jan 26, 2013
    57
    Netherlands
    I never replaced my routers because they broke, but because of new technology :p
  8. Mark the Red
    Mark the Red Occasional Visitor
    Sep 24, 2012
    34
    Google did a HUGE study of hard drive failures in their farms over time. It turns out there was very little correlation between operating temperature and fail rate. (corrected for obvious outliers such as drives catching fire due to faulty bearings, etc.)
    The biggest indicator of fail rate was actually time of failing. That if the hard drive was going to fail, it failed real fast (first months). Once it got past this "birthing" phase, a warmer drive lasted just as long as the cooler one.
    Now I can't say in any scientific way that a HDD lifespan has the same variables as a Router (i.e., moving parts). But my anecdotal experience of electronics for over 20 years is very similar to Googles. If its defective, it defects really fast. As long as you have reasonable air circulation around your router (not buried under laundry pile), and it hasn't failed in the first three months, Moore's law will "kill" it before the heat does.
    The only exception was a sound card I had that died after 5 years of use.
  9. Hothersale
    Hothersale Occasional Visitor
    Oct 23, 2012
    39
    Canada
    I'm on my third RT-N66U. The first died within minutes. The second died after three months. I chalk it up to bad luck, and I'm hopeful my new one will last a lot longer.
    Generally, I've had very good luck with electronics. My WRT54GLS was still going strong after 8+ years of continuous service!
  10. RMerlin
    Apr 14, 2012
    19,338
    Canada
    Life expectancy of electronic device can be wildly affected by the power supply. If you frequently experience power surges, then your electronic devices are more likely to experience an early failure.
    Quality power bars (not the $9 kind - and note that many power bars with surge suppression have a limited life as well) or even a small UPS can go a long way toward protecting your gear.
  11. Radiator
    Feb 26, 2013
    11
    Thanks for the info, I ordered the new router and ups today.
  12. netmik3
    netmik3 Regular Contributor
    Dec 8, 2012
    196
    Yup i have horrible electricity in this house and had several devices or power supplies. I bought more ups and voltage regulators.
    got tons of these http://amzn.com/B00009RA60
Share This Page
