services-start not starting
stafli
The last few times i've rebooted my router, the "services-start" script hasn't executed. I can manually execute it by the command "sh services-start", but I want it to automatically start.
File and location as in enclosed pic.
I've also noted that I cant execute a script by just typing it's name. I have to add "sh" before the name. Might this be connected to my first problem? As you can see, the shebang is in place and the file is set as executable.
I'm using the same "services-start" as I used to from the beginning - this problem came a few SW-releases ago.
Linux can be so frustrating at times! :(
So I have deliberately created a single-line script that is ambiguous and one would expect it to always fail, as it is missing the expected mandatory first line '#!/bin/sh' but depending on how you submit a request to execute it will actually run!
admin@RT-AC56U:/jffs/scripts# cat test7.sh
echo hello
admin@RT-AC56U:/jffs/scripts# test7.sh
-sh: test7.sh: not found
admin@RT-AC56U:/jffs/scripts# sh test7.sh
hello
admin@RT-AC56U:/jffs/scripts# ./test7.sh
hello
So I suggest you delete the first line or preferably recreate the file by hand ensuring you use a Unix compatible editor such as vi/nano or Notepad++ or via a WinSCP connection if using a Windows O/S
If you don't specify an absolute (/jffs/scripts/test7.sh) or relative path (./test7.sh), the specified executable is looked up in whatever directories are defined in the shell's $PATH. It can't find it there, so the shell says it couldn't find it. "echo $PATH" if you want to see those.
Thanks! I can now execute the script without entering "sh services-start" by entering full path. However, the question why "services-start" doesn't execute at boot remains.
are you sure it's the case of services-start not getting executed, versus your mount command actually failed at the time when services-start runs?
the reason being, at the time services-start runs, how do you so sure 192.168.1.10 is already connected and reachable (even if it's hardwired and static DHCP'd)?
also: for SURE you need
#!/bin/sh
as the 1st line.
#!/bin/sh
as the 1st line.
Thanks, I actually checked the log, and it says:
"Jan 1 01:00:14 custom script: Running /jffs/scripts/services-start".
However, further down in the log, I see:
"Jul 8 13:17:19 kernel: CIFS VFS: Error connecting to IPv4 socket. Aborting operation".
I tried to put in a "sleep 20" in the line after the "#!/bin/sh", but I got the same result.
Immediately when router has started, I manually telnet it and run the command /jffs/scripts/services-start, and cifs1 gets mounted.
Thanks for your help leading me to a solution - a "sleep 60" after the shebang did the trick!
Please check Adimistration > System page to make sure Enable JFFS custom scripts and configs option is turned on. It's a new option, added few releases ago.
