Shields Up! shows Port 0 'closed'...
OzarkEdge
Part of the Furniture
Can someone run the Shields Up! port scan on grc.com to see if your pseudo Port 0 is 'closed' instead of 'stealth'. I've never seen 'closed' before today. Nothing I do seems to clear this result to 'stealth' like it has always been before. Thanks!
OE
Stealth here on my RT-AC86U running the 384.14 Alpha2 builds.
Thanks! Now I'm annoyed! :D
A port nobody uses is responding for no purpose... it's always something.
OE
Does a reboot of all the network devices used to run that test help? :)
Stealth on my RT-AC1900P running 384.14 Alpha2.
Nope! :confused:
I have tried various changes:
o I've been wanting to retry 81049 again, so I upgraded from 45717 and tried each 86U standalone after ample resets with initialization and with WiFi switched OFF and with the entire LAN disconnected;
o I tried rebooting the primary Win7 test PC; then I disabled its adapter and tested with a mobile Nexus 7.
The only thing I have not changed is the cable modem and service.
I'm going to ignore it for now and come back later after Steve fixes his damn website! :D
OE
Well, today it is fixed. Thanks, Steve!
Now I can continue hiding from AndreiV. :p
OE
OE
01001111 01101000 00101100 00100000 01001001 00100000 01110011 01110100 01101001 01101100 01101100 00100000 01110011 01100101 01100101 00100000 01111001 01101111 01110101 00100000 00101110
01001001 01100110 00100000 01111001 01101111 01110101 00100000 01100011 01100001 01101110 00100000 01110011 01100101 01100101 00100000 01101101 01100101 00101100 00100000 01110100 01101000 01100101 01101110 00100000 01110111 01101000 01100001 01110100 00100000 01100001 01101101 00100000 01001001 00100000 01110111 01100101 01100001 01110010 01101001 01101110 01100111 00111111
OE
OE
Try this (clue: it's the common version).
00110 01100 00100 10000 10100 00001 00100 10011 11000 01010 01001 00101 00100 11000 01101 00100 01100 00001 01001 00100 01101 10010 00011 01100 01001 00001 01010 00101 11011 01100 11111 00100 01100 11000 10000 10100 00110 01100 11010 00100 00011 10000 00100 00011 10010 10010 11011 11100
OE
01100 11000 10000 00100 11100 00111 01110 10100 00100 11001 00111 10000 00100 10000 10100 00001 00100 01101 00110 11010 00100 10010 00001 00011 01101 00100 00110 00101 00100 00011 00100 01100 00110 01110 00001 00100 10000 11000 00111 01110 10100
