FreshJR
I've been wondering about this for a while.
With wifi-calling, I see that many devices are listening on the same port. How is this possible with regards to network address translation/??
Q1:
Does each packet arriving from 222.222.111.111:4500 simply get duplicated and pushed to all LAN devices that have an "ASSURED" connection in the NAT table. If this is the case, I am assuming that simultaneously any "non-ASSURED" devices would not be seeing any of this traffic?
Q2:
If I port-forward UDP:4500 -> 192.168.1.4:4500, would devices 1, 2, & 3 not see any of this traffic anymore?
OR
would all 4500 traffic always get forwarded to 192.168.1.4 (non-assured) && in addition to any assured devices (1, 2, & 3)
I assume that it gets pushed to all assured devices regardless of the port forward, but I would like to confirm since I never seen NAT (port address translation) have overlapping devices using the same port.
I ask because I just dealt with a friend on mine not receiving incoming calls on his VOIP device.
Sure enough I found that he had SIP disabled in his cisco router.
I was thinking of forwarding 500, 4500, 5060, 5061 to his VOIP device for good measure. I refrained from the port-forwarding since even though he had 1 VOIP device, he also has other Wifi-Calling devices which operate on the same ports.
If it was my router I would experiment and see, but since I was leaving I didn't want to cause service blackout issues on those devices.
udp 192.168.1.1:4500 222.222.111.111:4500 ASSURED
udp 192.168.1.2:4500 222.222.111.111:4500 ASSURED
udp 192.168.1.3:4500 222.222.111.111:4500 ASSURED
Q1:
Q2:
OR
