site to site vpn and remote vpn clients.
alanbridgestone
All,
I have established with a friend of mine a LAN to LAN connection which is working very well using powered by Asuswrt-Merlin version 380.65_2.
10.10.0.0 <->192.168.3.0
What is driving me crazy is that when a remote clients connects to 10.10.0.1 via a VPN connection where the client has all is traffic router via 10.10.0.1 the client see perfectly the LAN 10.10.0.0 but does not connect to any device which is on 192.168.3.0 and connected via the VPN channel.
What is the issue ?
Thanks in advance for your help
All,
What is the issue ?
We're going to need a bit more detail here. Do you have two VPNs running? It sounds like you have a LAN to LAN VPN which is working fine and then you're connecting a remote client to one of the LANs via another VPN and you can't see the remote LAN from that remote client -- is that correct?
You should probably post some screen shots from your Asus Merlin setup, especially from the router that has the two VPNs running.
