Smart connect: Iphones constantly bounce
leerees
RT-AX92u: Firmware: 3.0.0.4.384_9177
We have an issue with Iphones constantly bouncing, despite being sat next to one node with full signal. This could actually be the cause of the browsing lag our iPhone users are complaining about.
Looking in the admin panel it would appear it's bouncing between 2.4Ghz and 5Ghz but I can't be 100% sure. Smart connect is on default settings. I thought about turning down the power for 2.4Ghz but that would effect long range access.
Setting a longer dwell time quietens down the log entries but doesn't cure the problem and ultimately negatively effects seamless roaming.
Has anybody came up with a solution for this? If there's no fix, is there something we could change on the Iphones?
Reason code 8 = "Operating System moved the client to another access point using non-aggressive load balancing." That leads me to think it's something to do with smart connect.
 an 25 01:38:15 wlceventd: wlceventd_proc_event(499): eth6: Auth 8A:80:BB:8C:91:9B, status: Successful (0)
Jan 25 01:38:15 wlceventd: wlceventd_proc_event(509): eth6: ReAssoc 8A:80:BB:8C:91:9B, status: Successful (0)
Jan 25 01:38:15 wlceventd: wlceventd_proc_event(481): eth5: Disassoc 8A:80:BB:8C:91:9B, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jan 25 01:38:18 wlceventd: wlceventd_proc_event(499): eth5: Auth 8A:80:BB:8C:91:9B, status: Successful (0)
Jan 25 01:38:18 wlceventd: wlceventd_proc_event(509): eth5: ReAssoc 8A:80:BB:8C:91:9B, status: Successful (0)
Jan 25 01:38:18 wlceventd: wlceventd_proc_event(481): eth6: Disassoc 8A:80:BB:8C:91:9B, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jan 25 01:45:18 wlceventd: wlceventd_proc_event(499): eth6: Auth 8A:80:BB:8C:91:9B, status: Successful (0)
Jan 25 01:45:18 wlceventd: wlceventd_proc_event(509): eth6: ReAssoc 8A:80:BB:8C:91:9B, status: Successful (0)
Jan 25 01:45:18 wlceventd: wlceventd_proc_event(481): eth5: Disassoc 8A:80:BB:8C:91:9B, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jan 25 01:46:14 wlceventd: wlceventd_proc_event(499): eth5: Auth C6:22:E0:B6:CA:8C, status: Successful (0)
Jan 25 01:46:14 wlceventd: wlceventd_proc_event(527): eth5: Assoc C6:22:E0:B6:CA:8C, status: Successful (0)
Jan 25 01:46:18 wlceventd: wlceventd_proc_event(464): eth5: Deauth_ind C6:22:E0:B6:CA:8C, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Common advise it to turn OFF smart connect and set the channels yourself (non DFS on 5ghz). Let your clients pick/choose where to go, not forced by the router. Most here abide by that, by you'll see one or two who say otherwise.
The mesh is working well for all other devices, it's only the iphones that are suffering.
We don't want to separate the bands as we want seamless roaming.
I don't use the mesh capabilities so I'll bow out to those that can give better input.
