My first post in this forum - http://www.snbforums.com/threads/need-advice-on-vpn-routers.34672/ - discussed my need to find a vpn router. My needs are very simple. I am the only user. I need to connect remotely to view and manage one security cam. When I connect, no one will be using the computer that the VPN server is running on.
After much discussion and consideration, I decided to install SoftEther VPN - https://www.softether.org/ - and use L2TP over IPSec to create a VPN tunnel to my home network. Installing and configuring it was very simple. I won't detail it here, because they have excellent tutorials that do that - https://www.softether.org/4-docs/2-howto
It's open source and completely free (provided by a Japanese university) and available for Windows, Mac and Unix/Linux. It even includes a free dynamic dns service, which makes getting up and running very simple.
There was one catch that I either missed or was neglected in the docs. After I setup the virtual VPN host and the L2TP over IPSec tunnel, I could connect and authenticate but then the connection was dropped. It turns out you have to create a bridge between the virtual VPN adapter and the physical adapter of the machine that's running the server.
I can now connect to my VPN server from the internet using my Mac and my iPhone, which is very convenient.
A note for those who aren't too familiar with L2TP over IPSec. You have to open 3 UDP ports on your firewall (or forward them on your router); 500 udp, 1701 udp and 4500 udp.
For those of you who don't have high demand issues, or have a box that isn't being heavily used, this might be the solution to a low cost VPN alternative.
