Viktor Jaep
Part of the Furniture
Hi all,
I have an RT-AC3100. I read the documentation on split tunneling (https://github.com/RMerl/asuswrt-merlin/wiki/Policy-based-routing), and did some forum searching, but didn't see any an answer to the particular scenario I have.
I'm planning on again using a StrongVPN openvpn connection (which successfully worked on the stock Asus firmware) to protect all my local network traffic across a VPN, but ran into problems with my Voip device, as it would continually go offline, or lose connection somehow while everything else was going out over the VPN. When I found that Merlin could handle split tunneling, I was hoping to:
1.) Have all traffic on local network traverse across the VPN
2.) Except for a specific IP for my Voip device, which will need to go across the WAN.
So based on this, I'm not sure if I can use CIDR for my internal range, and if so, if I specifically reference this Voip device IP which will be included in the CIDR range, will the router know to make an exception for it and make it's traffic go out through the WAN?
Hoping to do something like this:
LocalNetwork 192.168.1.0/24 0.0.0.0 VPN
VoipDevice 192.168.1.100 0.0.0.0 WAN
Would something like this work, or should I be going about this a different way?
Thank you,
Viktor
Thank you,
Viktor
