I realise this has been referenced on another post (https://www.snbforums.com/threads/rt-n66u-koolshare.56351/) but I'm having this issue suddenly pop up after using the offical AsusWRT-Merlin firmware without ever having used "Koolshare"
When I login via SSH as per normal the router suddenly comes up with:
-sh: source: line 4: can't open '/koolshare/scripts/base.sh'
admin@RT-AC88U-E268:/tmp/home/root#
Whats concerning after reading the last post is that I didn't even know of any other unofficial/illegal alternate firmware called Koolshare - as far as I know the router only ever previously had the offical Asus stock firmware when I previously bought it.
The issue only appeared after the Diversion stopped working - from what appeared as a USB drive failure.
I proceded to take USB flash drive offline and performing a "Health Scanner" check via the routers admin page which listed a few errors that I assumed may have been caused by a sudden power loss.
I only noticed this when Diversion and Skynet appeared to not be working - but after a reinstallation (the reinstaller found the previous configuration files and reinstalled over the top) the following "-sh: source: line 4: can't open '/koolshare/scripts/base.sh'" started to appear.
I can categorically confirm that I'm on the offical Merlin firmware (384.14_2 on AC88U) so I'm left perplexed - if not a bit concerned.
Assuming its trying to start a non-existent script is there anyway to edit any boot up SSH files to be able to remove the problematic "line 4"
Many thanks in advance for any advice!
